Shallow well pump issue
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by kddeford, Apr 17, 2012.
  1. kddeford
    kddeford New Member
    Apr 17, 2012
    Florida
    Hello all,
    I think i messed up. I only have a rudimentary knowledge of well pumps (installed/piped this one a year ago).
    I have a Hydrostar 1hp shallow well pump (a harbor freight cheapie). I found an old shallow well on the property and piped this in for watering my vegetable gardens. Well I got the bright idea that I would drain the pool down a few thousand gallons and refill it with this well. I figured if i only ran it half pressure for half an hour at a time and then gave it half an hour off it would work. Well when it was time to stop for the night I turned it off and unplugged the pump (it was operating fine when i unplugged it). Today when I got home I screwed on the nozzle and started watering my garden. After about five gallons of water it dryed up and then i remembered that i hadn't plugged the pump back in. To make a long story a little shorter after plugging it in nothing happened so I confirmed power in the plug, made sure the bladder still had 28 pounds of pressure (it was a little low so i boosted it back up) and tried again. Regrettably nothing happened.
    Now I did notice that the pressure gage is at zero even though the bladder reads 28 when checked manually (with a tire gage).
    Any ideas?
    Thanks,
    Kenny
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The pressure tank has nothing to do with your problem. Either you still don't have power to the motor, or the motor has an open circuit and needs to be replaced.
  4. kddeford
    kddeford New Member
    Apr 17, 2012
    Florida
    yep
    You were one hundred percent correct. Apparently something happened to the powercord. I cut it off and replaced three quarters of it with a new cord and the pump kicked on without a problem.
    Thanks valveman, you probably saved me a couple hundred dollars replacing the setup.
    Kenny
Similar Threads: Shallow pump
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump installation Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Jet Pump Recommendations? Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Filter before shallow well pump? Dec 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump w/ 1"intake May 23, 2016
