shallow well problem
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by kevinm63, Jun 13, 2005.
  1. kevinm63
    kevinm63 New Member
    Jun 13, 2005
    i just bought an old house to fix up. the well is a shallow well with what appears to be a new f/w pump and motor on it. we intend to put in a new 5" submersable at some point, but we would like to get the water working for now so we can clean paint brushes and things. the wiring to the pump had been cut so i ran a new wire to it. when i turned the breaker on nothing happens. when i close the points on the pressure switch the pump will run and push water through it however after 5 or 6 seconds it cuts out. i can hear a click in the motor. i release the points on the pressure switch. after 15 seconds the breaker? in the motor closes again and if i close the points on the pressure switch again we can repeat the process all over again.
    any ideas?
  2. Gary Slusser
    Retired
    What voltage is the pump and what voltage are you feeding it? It sounds as if the thermal overload is opening due to heat or you have the wrong voltage or wired wrong.
    And I think you meant to say a 4" submersible.
    Gary
    Quality Water Associates
  4. kevinm63
    kevinm63 New Member
    Jun 13, 2005
    Hi Gary
    I had an electrician friend look at it and he said that everything was hooked up right. What else would make the thermal overload trip?
    thanks
    kevin
  5. Gary Slusser
    Retired
    A bearing overheating, a broken impeller or seal, bent shaft, or blocked jet, something preventing it from getting water... a short in part of the wiring or windings? If this is the one that only runs a few seconds, the shaft would be stopped from rotating. Something with the thermal overload circuit...
    Gary
Similar Threads: shallow problem
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump problem Jan 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well problems - sorry about double post. Oct 13, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Shallow or bored well pump problems Jun 3, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well/spring pump problem Feb 23, 2015
Pumps and Tanks Well Forum & Blog. Water is life. SHALLOW WELL JET PUMP PROBLEM Aug 6, 2014
