shallow well loses prime and no pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by chefallen, Apr 12, 2007.
  1. chefallen
    chefallen New Member
    Apr 12, 2007
    I just moved into a house with a shallow well, after finally getting it primed and flowing; it doesn't put out much water. It can build enough pressure to turn off the pressure switch, but after 5 minutes loses pressure and switch kicks pump back on. If I turn it off it loses prime altogether. It's all old galvanized, I don't see a check valve but that doesn't explain the lack of continous pressure when the pump is running. any help?
  2. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    As far as loss of flow and pressure you could have a vacume leak in front of the pump or the well screen could be getting plugged up.
    SAM
  4. chefallen
    Apr 12, 2007
    blowout screen?
    Should I run a hose down the well to blowout screen?
  5. chefallen
    Apr 12, 2007
    snaking out old pipe
    Some one suggested that the old galvanized might be closing up with rust; that would explain a slow build of pressure but not a loss of prime on a closed system
  6. sammyhydro11
    Dec 20, 2006
    Massachusetts
    Assuming the point id plugged,I would get yourself a hand pump,thread it to the top of the well,and see if you can redevelop it.
    SAM
  7. ron in sc
    ron in sc New Member
    Mar 30, 2005
    South Carolina
    I had that same problem on my 20 year old shallow well. I ended putting a new point down about 7' from the old one and I get water again. So far if I don't use it for a day or so it never loses pressure so the pump does not have to run. When I have used it does not lose prime either. I mounted the check valve right at the top of the well point after it makes a 90 degree turn. The run to the pump is about 12'.
  8. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    You said it's a shallow well, do you think it's a driven well or a well that might be out in the yard? With no check vavle in plain sight, you might have a two inch well or larger with a drop pipe and a check vavle in the well on the end of the drop pipe. If that's the case, you will need a pro to change or acid treat that screen for you.
    bob...
Similar Threads: shallow loses
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well loses prime Jun 15, 2010
Pumps and Tanks Well Forum & Blog. Water is life. shallow well jet pump loses prime at 50psi Jun 30, 2008
Pumps and Tanks Well Forum & Blog. Water is life. shallow well pump loses prime overnight Aug 7, 2005
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump installation Feb 10, 2017
