twodogs
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I have a shallow well pump hooked up to my 1000 gallon cistern. I have a simer 1/2 hp convertible shallow well jet pump. I can't get it to run at the proper pressure. I have a 30/50 switch, but I can't seem to get the pump to run until it hits 50 lbs. The pump labors forever, so I end up shutting it down. I have set the pressure tank to a 18 lbs & adjusted the switch to be a 20/40 switch, but the tank ends up emptying out, the pump looses its prime. Should I start over with an empty tank? The water isn't been carried that far to the pump - less than 25'. I am at a loss. I have read several threads, & I do not have a check valve on the line - didn't know if that was necessary. The drawings that I had for install didn't show it.
Any help will be greatly appreciated!
