Shallow Well and a Trash Pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by muddydawg, Sep 8, 2010.
  1. muddydawg
    muddydawg New Member
    Sep 8, 2010
    Marianna, FL
    New to the forum. Lots of useful info but couldn't find a answer to my question so I decided to post up. I have a small cypress pond. Dry but the soil is soft and wet. I am wanting to flood it to with about two- three feet of water maybe twice a year and control the flow so I can manipulate the water level. This would be pond is in the middle of the woods so I need a water source. So in comes the idea of a shallow well.
    I'm not asking about the installation process. Already found a good bit of info posted. My question is what size pump should I use? Is there a chance I could use say a trash pump to pump the water out of the well and flood the area? Then disconnect the trash pump. No electricity for miles.
    Thanks for the help and any information.
  2. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    You can do this and it can work with spectacular results. First thing-you need to be either at or near sea-level. Assuming that you are in Florida then you have that one covered. The 2nd thing is that you need a relatively high water level, like around ~10 feet. Since a centrifugal pump doesn't work exactly like a shallow well jet they have a hard time getting started or primed.
    What we normally do around here is directly connect a 2" suction hose directly to the casing on a 2" well. You then fill as much water in the pump as fast as you can. You probably won't be able to fill up the casing/pump without a footvalve but you can raise the level a little. Start the pump and hope it primes/picks up. You may have to wait several minutes. Beware running your pump dry for very long as the seals etc. can burn up.
    You can get a solid 30-60 gpm of water out of a correctly done set-up like this, depending on well yield etc.
    Good luck.
  4. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    Also I have seen some use a smaller trash pump so that a footvalve can be used, which makes it easier to get the pump primed etc. The down-side is that you won't have as much flow. I'm unaware if any gas powered jet pumps exist but it might be worth a search.
  5. muddydawg
    Sep 8, 2010
    Marianna, FL
    Thanks for the information. I will search around for the jet pump. I appreciate your time! Will post up when we have it complete. Thanks again.
Similar Threads: Shallow Trash
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Threads Trashed? Apr 21, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Wednesday at 7:59 AM
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump installation Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Advise Jan 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Jet Pump Recommendations? Jan 4, 2017
