sewerage problems
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by curiousgeorge, Aug 1, 2006.
  1. curiousgeorge
    curiousgeorge New Member
    Aug 1, 2006
    My name is george and I live in NSW, Australia.
    My sewer is blocked between the inspection plate and the main sewerage pipes; there is only one metre between the two.
    I have dug to about a metre from the main sewer pipe and opened an inspection hole.
    Do I have to dig all the way to the main? Or does anybody know how my sewer connects with the main?
    For example, does my sewer pipe go all the way to the main and then drop vertically? Or does it go diagonally or any other way down?
    Thanking you in advance,
    George.
  2. jadnashua
    It's hard to say. In the USA, sewer lines typically slope around 1/4" per foot. Note that larger pipes don't need quite that much slope, and more is okay as well. Normally, where there is a 90-degree angle, there is a cleanout since an auger or snake with a cleaning head on it has trouble sometimes going around that bend. Good design would probably dictate that from the cleanout/inspection it runs fairly straight to the main sewer line.
    Tree roots are one common thing that will block up sewer lines. Another is a collapsed or broken line that can happen if any heavy construction equipment was running over the area.
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Don't they have to slope up in Australia?
Similar Threads: sewerage problems
Plumbing Forum, Professional & DIY Advice Plugging Sewerage Drains Information Dec 25, 2012
Plumbing Forum, Professional & DIY Advice What if sewerage backs up into tub? Mar 30, 2011
Plumbing Forum, Professional & DIY Advice Sewerage/sulphur smell in house? Jun 30, 2008
Plumbing Forum, Professional & DIY Advice sewerage ejector pump Apr 6, 2008
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
