Sewer gas
Discussion in 'Toilet Forum discussions' started by wptski, Apr 22, 2013.
  1. wptski
    wptski Retired Machine Repairman
    Oct 20, 2012
    Warren, MI
    As I understand it, sewer gas may contain methane gas. I remember back when I was replacing my toilet flange I ran across this video:
    Watch it and tell what you think about its procedure?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I don't use a torch to remove poured lead, because it is unnecessary, but how else would you sweat copper drain pipes?
    There has been a couple of documented cases of natural gas leaking into the municipal sewer, which could be a much bigger concern. Luckily is is almost unheard of.
  4. wptski
    Oct 20, 2012
    Warren, MI
    I drilled holes and cut the webs with a Fein Multimaster on mine. I don't get the need to melt the wax anyway.
    If your sweating a copper drain, your open flame would be on the outside of the pipe at least.
    Just had locally two workers at a water treatment plant killed while using a torch on top of a huge tank. Both were blown off the tank to a nearby building roof. Methane gas is suspected.
  5. jadnashua
    One reason there's a vent on the roof is to allow any gasses to disperse before they build up. It also helps ensure things can drain well. In a residential environment, it would be a set of very unusual circumstances where you could even get anything to ignite any sewer gasses, then, it would act more like a burner rather than a bomb. Now, playing around an enclosed tank or something, that's a totally different story.
Similar Threads: Sewer
Toilet Forum discussions New Home Sewer Line Clog Jan 8, 2017
Toilet Forum discussions Flushable Wipes? The damage and cost to the sewer systems Nov 7, 2016
Toilet Forum discussions Re-route of back-to-back toilets to new sewer hook-up Sep 1, 2016
Toilet Forum discussions Weird toilet sewer drain help??? Jul 26, 2016
Toilet Forum discussions Toilet Sewer Odor Issue Apr 30, 2016
