Sewer gas smell in the bathroom
Discussion in 'Shower & Bathtub Forum & Blog' started by klewis, Jul 16, 2009.
  1. klewis
    klewis New Member
    Jul 16, 2009
    For about a year we have off and on smelled sewer gas in our bathroom. There is a tub and also a sepoarate shower. It appears that the smell comes from the tub. The tub is seldom used. It is the drain closest to the sewer line. The tub runs along an outside wall with drain and handles backing up to my closet. I could cut thru the wall in the closet and I would be at the water and maybe drain or vent.
    My pluimber said to try to not let it dry out. Good idea but water every few days helps but the smell does return. It has been very hot here in Dallas this summer.
    What can I do to determine that it is this p trap?
    If it is then what are my options to fix or repair or seal?
    If not then what?
    KL
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    If pouring water in the trap helps but the smell returns after only a few days I would suspect there is an issue with the trap, maybe it's leaking. The trap should take longer to dry out - at the very least a couple of weeks. I'm in South Florida so I know heat - we have a second bath that used to get used very infrequently and never had a sewer smell issue.
  4. hj
    trap
    Put RV antifreeze into the drain to eliminate the frequent evaporation of the water in the trap.
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Smell in bathroom
    Have you opened up the ceiling below to inspect the P trap? Perhaps the P Trap is plumbed wrong and is actually a S Trap which will not hold water every time.
    Many times after a remodel the floor heigh changes and the tile guy reinstalls the toilet with the wrong rings and gaskets. I would first check the toliet and the toilet flange and the the Bath tubs P Trap.
Similar Threads: Sewer smell
Shower & Bathtub Forum & Blog Sewer gas smell in shower only with hot water running Apr 28, 2012
Shower & Bathtub Forum & Blog Puzzling case of sewer smell only while showering Oct 19, 2009
Shower & Bathtub Forum & Blog Bacteria or sewer smell Apr 9, 2005
Shower & Bathtub Forum & Blog Home addition with bathroom plumbing sewer line connection issue Jan 13, 2015
Shower & Bathtub Forum & Blog Broken Sewer Line Jan 10, 2015
