sewer gas in master shower drain ???
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mkpaluv, Aug 18, 2005.
  1. mkpaluv
    mkpaluv New Member
    Aug 16, 2005
    I have sewer smell coming from my shower drain. There is nothing plugged and the water heater is new (we have tried other water in the house, no smell). When we flush the toilet in this bathroom, there is gurgling in the pipes and when we watch the shower drain, the water level goes down, then bubbles a little and fills back up. This is when we smell the sewer smell the most. Also, when we shower first thing in the morning, the smell is bad. We had a bunch of water leaks (frozen pipes) from this bathroom when we bought the house 4 months ago and had them all repaired. Is this related? How do I fix it? Please say I don't have to tear into the ceiling below it - I just had it re-drywalled!!!
    Wendy
  2. mkpaluv
    mkpaluv New Member
    Aug 16, 2005
    extra info
    I forgot to mention, we are on city sewer and water and none of the neighbors have the problem!
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm not sure what the problem is exactly, but let's eliminate some of the things you are questioning. The problem is in no way connected to the source of your water, or to the repairs in the water supply lines. It is a drain problem. The sewer gas is getting past the trap in the shower when the water in the trap recedes as the toilet is flushed. This may be due to improper venting, but I'm not sure. I would hope HJ, Terry, and/or one of the other pros will have a better idea of why the water is sucking out of the trap.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    smell
    Sounds like your drain in that area of the house is partially plugged, or that the drain may be pitched uphill a little.
    Can you run a hose up on the roof and down the stack for that bathroom
    Also you should be able to use the 2" trap in the shower for a c.o.
    See if you can get a Kohllman or Ridig electric drain cleaner an clean drain from the shower trap....
  6. Terry
    Aug 17, 2004
    Sounds like the toilet is siphoning out the trap.
    If the shower drain had a vent between the trap and the main line, it would prevent that.
    Looks like someone saved a buck and now you have this problem.
    I think think that stinks!
  7. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    i agree with terry
    sounds like missing vent to me also
Similar Threads: sewer master
Plumbing Forum, Professional & DIY Advice Sewer smell in house Mar 17, 2017
Plumbing Forum, Professional & DIY Advice Sewer-ish smell in basement kitchen Mar 13, 2017
Plumbing Forum, Professional & DIY Advice Our seemingly never ending sewer line under the house problem Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Sewer smell in apartment, HELP :( Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
