Sewage pit problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by leesouthern, Oct 26, 2008.
  1. leesouthern
    leesouthern New Member
    Oct 26, 2008
    I've searched the threads here and I seem to have a unique problem...
    I moved into this 20 year old house 6 years ago, and have just removed the lid from the sewage pit for the first time. It seems that the plumber couldn't figure out how to connect the drain from the main floor and from the basement bathroom & laundry through the same drain hole on the tank, so he hooked up the basement drain to the drain hole and made a new hole for the main floor drain.
    It looks like the second hole was originally sealed with cement, which has since fallen out into the pit. I can see water from the main drain is leaking outside of the pit, and I'm pretty sure groundwater is leaking back into the pit too.
    It seems I have two options:
    1. tie the basemnet and main drains together and replace the pit
    2. try to seal this hole somehow.
    Obviously option 2 would be much cheaper and easier, but what could I seal the hole with? The gap is over an inch wide in places.
    Can this hole be sealed?
    Any help would be greatly appreciated!
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would suggest looking here to see if you could find either a rubber grommet or, bulkhead fitting that would provide the seal that you need.
    http://www.mcmaster.com/
  4. leesouthern
    Oct 26, 2008
    Thanks for the link. I've decided to go down the "patch it up" route, wish me luck...
  5. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    What is a "sewage pit"? If you are referring to a septic tank then I suggest that you spend a couple hundred dollars to have it pumped out and maintained before it burps into your leach field and costs you several thousand dollars. Then repeat in 3 year intervals.
  6. leesouthern
    Oct 26, 2008
    Sorry, I guess "sewage basin" is the correct term. I saw "sewage pit" used on a different forum and I guess it stuck in my head.
  7. Southern Man
    Jun 27, 2008
    North Carolina
  8. leesouthern
    Oct 26, 2008
  9. Southern Man
    Jun 27, 2008
    North Carolina
    Gotcha! You have a grinder pump to the septic tank. Regardless, I'd advise you to pump the septic tank ASAP and in 3-4 year intervals. Good luck with the other totally separate issue.
Similar Threads: Sewage problem
Plumbing Forum, Professional & DIY Advice Sewage Ejection Pump Problems Nov 28, 2010
Plumbing Forum, Professional & DIY Advice sewage odor/mold problems Jan 1, 2008
Plumbing Forum, Professional & DIY Advice Intermitent Sewage Pump Problem Mar 1, 2007
Plumbing Forum, Professional & DIY Advice Sewage ejector-water table problem Jul 18, 2005
Plumbing Forum, Professional & DIY Advice Shower rough in has standing sewage? Saturday at 6:43 PM
