Sewage Ejector Pump Lid needed
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by lowe, Nov 27, 2011.
  1. lowe
    lowe New Member
    Nov 27, 2011
    Vancouver BC Canada
    Hello,
    I have a sewage ejector pump in my basement. The pit is 24"across when measured with the lid off, and the lid is 26". Based on measuring with a stick from the top of the open tank, it is about 33" deep. I would like to change the lid to a steel lid, but I can't find the manufacturer of the pit/basin. I've included a picture.
    Other questions include:
    1. I know there are check valves that don't slam. How reliable are they?
    2. Should/can I attach the waste pipe to a concrete wall via braces to avoid vibration?
    3. The pump is approx 9 years old. I am doing renovations in the basement and adding several fixtures - should I replace the pump if it is not malfunctioning? (I don't want a flood ever....)
    4. In the basement I will have 2 bathrooms (2 lav sinks, 2 toilets, and a shower), a kitchen with dishwasher and sink, a laundry room with washer and steam dryer, and heat pump condensate. What size pump do I need?
    5. Can I vent a toilet and sink to the same vent that serves the ejector?
    Thanks for any info!
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Why do you want a steel lid?
    I wouldn't replace the pump unless necessary, but that depends on the model and age of it as well... I would however install an audible level alarm regardless.
  4. lowe
    lowe New Member
    Nov 27, 2011
    Vancouver BC Canada
  5. dlarrivee
    Jun 28, 2009
    Canada
    I don't know that they're universal, but the one I have sure looks a lot like others I've seen.
    I've never seen a steel lid, but you could have a shop make you one up that will fit OVER the existing one?
  6. lowe
    lowe New Member
    Nov 27, 2011
    Vancouver BC Canada
    That's an idea. The work I'm doing is by permit though.... i wonder whether putting a lid over another lid would pass?
    What about the size of the pump? Is there any way to tell size without pulling the pump out? What's the appropriate size for the number of fixtures I'll have?
Similar Threads: Sewage Ejector
Pumps and Tanks Well Forum & Blog. Water is life. New Bathroom Sewage Ejector Pump/ Pit Tie In Apr 12, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Sewage ejector piping in ABS Jul 31, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Sewage ejector pump running too frequently? Apr 20, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Advice Requested Best Sewage Ejector System for New Construction Feb 27, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Advice on Sewage Ejector systems Nov 16, 2009
