Several Questions involving pipes/plumbing/septic tanks?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ForeclosureGreenie, Jan 7, 2009.
  1. ForeclosureGreenie
    ForeclosureGreenie New Member
    Jan 7, 2009
    X-ray Tech
    Middle of North Carolina
    Hi, I am very new here found the site while trying to gather information about wells, pipes, carpet and drywall, etc...
    I am considering the purchase of a 1400 sq foot farmhouse built in 1925. The outside seems to be in excellent repair, new siding windows and doors, and the inside looks outdated and dirty but not terrible.
    This is a foreclosure, so I was warned that there maybe problems with the pipes, or well. And have heard from the boys that I work with that sometimes people dump cement down the toliet, or stuff dishrags in the pipe lines so they will not work.
    So, Not knowing much about pipes I thought I'd ask;
    What would be a rough estimate for a total house repipe-job in the Middle North Carolina area? The house has a crawl space, so pipes are accessible underneath...there is only 1 bathroom...though I'd like to add a half bath perhaps....
    Does anyone know what it cost to re-do, clean out a septic tank incase that is bad?
    And how much is it to drill a well incase this one is bad.....oops, that's a lot of questions. :eek:
Similar Threads: Several Questions
Pumps and Tanks Well Forum & Blog. Water is life. Several questions Re: new filtration system Aug 24, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank replacement - CSV, new pressure switch ? Several questions Aug 7, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Pump cycles on and off several times, stops at 20 psi Apr 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Lost Water - turned controls on Pumptrol several times and not sure what to do!! Apr 6, 2011
Pumps and Tanks Well Forum & Blog. Water is life. several foot valves stuck in well casing! May 3, 2010
