Settting option for preformed shower pan
Discussion in 'Shower & Bathtub Forum & Blog' started by msrazmataz, Mar 22, 2010.
  1. msrazmataz
    msrazmataz New Member
    Mar 22, 2010
    Indiana
    I have purchased a pre-formed shower pan for a stand alone shower. It has a formed grid base on the bottom. Someone mentioned that there is a new foam type product to set such bases in versus using the old morter bed process.
    Does anyone know if this true and if so the name/type of product and where it can be purchased?
    Thanks so much for any information.
    Kind regards,
    msrazmataz
  2. jadnashua
    If your floor is not perfectly flat and level (and so is the pan!), mortar is still your best choice.
  4. xdeaconx
    xdeaconx New Member
    Dec 15, 2009
    chicago
    why mortar as opposed to concrete? Is there ever a time to use one over the other?
  5. jadnashua
    Concrete will sag and run, mortar won't (if you use the right stuff) and will stay where you need it while is cures.
  6. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    foam will compress over time, while a properly set mortar bed will provide solid support!
  7. xdeaconx
    xdeaconx New Member
    Dec 15, 2009
    chicago
    That makes perfect sense. What's the "right stuff" as far as mortar is concerned? Should it ever be used to finish off the leveling of the acrylic base?
  8. jadnashua
    Many people use deck mud, this is a mostly sand mix with enough portland cement to hold it together. It is closer to wet beach sand than what you think of as concrete that you'd make a sidewalk out of. Another substance that is used is Structolite (sp?).
  9. xdeaconx
    xdeaconx New Member
    Dec 15, 2009
    chicago
    hmm, deck mud, I think i remember something about that over at john birdges website. Sounds like something I'd have to mix myself. Maybe i can find a recipe online somewhere.
    EDIT
    I found the site talking about deck mud, in case anyone else want's to see what it's all about
    http://www.johnbridge.com/how-to/deck-mud/
  10. jadnashua
    You can buy sand mix in bags. It is fine for setting a shower base. It's a little rich (too much cement) for a shower pan construction for some (too much cement makes it stickier and not as porous), but that means it will 'smush' easier than the mix with a higher sand content. Put a piece of tar paper or some plastic on the floor before setting it to prevent the wood from sucking too much moisture out.
  11. xdeaconx
    xdeaconx New Member
    Dec 15, 2009
    chicago
    got it jada, i'll look for the sand, portand mix.
    thanks
  12. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    If you use foam you need to put somthing in the pan to weigh it down untli the foam finishes expanding and cures, otherwise it will push up on the shower pan.
Similar Threads: Settting option
Shower & Bathtub Forum & Blog Rotted subfloor under cast iron tub, considering my options. Oct 10, 2016
Shower & Bathtub Forum & Blog Delta Lucite and fixture colored to Brushed Nickel - Options or Leads? Jun 20, 2016
Shower & Bathtub Forum & Blog Best option for shimming Cambridge tub level Sep 30, 2015
Shower & Bathtub Forum & Blog Tub repair options Sep 5, 2015
Shower & Bathtub Forum & Blog Symmons shower swap out option May 15, 2015
