I recently remodeled my bathroon in my basement. Althought I've set toilets before I've never run into this problem before. I installed Dricore before I put down a laminate flooring and the distance between the drain-flange and the toilet increased considerably. I had the bright idea of using 3 wax rings (one with the plastic flange on it) to make sure the set was watertight and here 5 months later the bowl is leaking. It has to be a wax ring failure and I fear it just didn't seal well because I uses so many rings. Two rings were too little and three were just a bit too much. Can anyone suggest how I might fix this problem with out having to install a new drain-flange that is taller?
Thanks for any advice.
Novacks
Novacks
