Service water line entrance "Split entrance" house, slab floor...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by EltonT, Jun 12, 2011.
  1. EltonT
    EltonT New Member
    Jun 12, 2011
    Covington Wa.
    I live in the Seattle area and I have a split entrance home which quite common in this area.
    My service line has broken again, first time was a tree root. I am going to start the dig tomorrow to see if it is the same leak again. If it is, then I have to run a new line as we were unable to remove the trunk and root system as someone in the past planted a fir tree right on top of the water line. We can't root it out as that section of the property is used by the neighborhood utilities and all of the lines run under tree.
    How do I find out where the service line entrance for the house is? The shut off valve sits about 3/4 of the way into the garage, and the line runs underneath the poured slab floor. I can see that the pipe runs up from the floor, but is it a good guess that it runs straight across to the outside. If so this would put the entrance where the utilities, phone, gas, electric are stationed.
    Any help would be great.
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Cincinnati OH
    It is called call before you dig! Contact your local utility company!
    This is the number for your area.
  4. Terry
    Aug 17, 2004
    Many times on slab homes in that area, the soft copper was laid out of the garage past the foundation and aimed towards the water meter as it left the foundation.
    You can try witching for the pipe with a coat hanger. Anything installed in the 70's and later was most likely the black poly pipe.
    I look pale as a ghost here. I had just lost 45 pounds and was on pain killers.
    I think I need to reshoot this. My avatar picture at the left was taken a few months later in the Summer when I had put back 40 pounds. There was a little surgical error in February of that year.
  5. hj
    If the tree roots are breaking the pipe, then I assume it is PVC plastic because a metal pipe would not be affected by them. If so, NOTHING will locate its route, although "witching", or even guessing, might give a reasonable route.
Similar Threads: Service water
Plumbing Forum, Professional & DIY Advice Water Service line to house/outdoor faucet branch... needs a look. Jul 2, 2015
Plumbing Forum, Professional & DIY Advice Water service fittings pack joints May 3, 2014
Plumbing Forum, Professional & DIY Advice 1 1/2 water service to home aprox 1300 ft. Mar 5, 2014
Plumbing Forum, Professional & DIY Advice Need expert help, polybutylene water service? Oct 7, 2013
Plumbing Forum, Professional & DIY Advice Water service upgrade for home fire sprinkler Apr 1, 2013
