Service Disconnect Fuse Contacts
Discussion in 'Electrical Forum discussion & Blog' started by dave9600, Jan 10, 2009.
  1. dave9600
    dave9600 New Member
    Jan 1, 2009
    The service disconnect for our air handler has two 60A time-delay fuses. The fuse contacts (where the fuses plug into the disconnect) are oxidized. This is causing fuse failure. Two questions:
    1. What is the best way to clean the oxidation off the contacts? A wire brush didn't do much good.
    2. P=I^2xR. So as the resistance across the fuse increases because of the oxidation the heat is increasing across the fuse leading to premature fuse failure. Am I understanding this correctly?
  2. hj
    fuse
    You may also be incorrect as the the cause of the problem. If that situation has occurred, the contacts inside the switch have probably been overheated so they no longer have the ability to make a tight connection to the blades, and that is what is causing the heating condition.
  4. dave9600
    dave9600 New Member
    Jan 1, 2009
    Unless you're talking about a switch inside the unit itself I'm not sure I understand. There isn't a switch at the disconnect.
  5. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    Your equation is correct and your assumption is likely correct too. What may be a complicating problem is the springy-ness of the fuse clips in your disconnect box is now fatiqued from heat. If so they likely are not applying enough force to keep intimate contact with the new fuse.
  6. dave9600
    dave9600 New Member
    Jan 1, 2009
    So I would be better off just replacing the disconnect altogether. That's kinda what I figured. :mad:
  7. Probedude
    Nov 25, 2008
    CA
    It would solve the problem if this is truly where your failure is.
    Have you confirmed that the fuse clips are heating up when the air handler is in operation (using an IR camera or thermometer)?
    Has anything changed on the air handler? (new motor, new blower, change in pulleys or pulley ratios).
    Dave
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Of course there is, why do you think they call it a disconnect?
  9. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Because the I squred R losses are making the fuses blow? :D
    I would think that the best avenue would be to put an ammeter on the conductors and see what the unit is drawing but then again what do I know?
  10. hj
    disconnect
    "Disconnect" implies a switch at the fuse site, either a rotating switch or a pull out fuse holder. Either of these will lose their temper and tension if overheated by poor contact.
Similar Threads: Service Disconnect
Electrical Forum discussion & Blog Heat pump service disconnect Jan 28, 2013
Electrical Forum discussion & Blog Building Service Disconnect question Jan 21, 2012
Electrical Forum discussion & Blog Water heater service disconnect question Aug 14, 2010
Electrical Forum discussion & Blog 200-amp Service to 100-amp Service Sep 21, 2016
Electrical Forum discussion & Blog 200 amp service split between two panels Mar 14, 2016
