Statjunk
DIY Senior Member
- Messages
- 540
- Reaction score
- 0
- Points
- 0
Hello Guys,
This is a very difficult situation that I'm currently in and would like to see if there is a good way to get out of it.
The house I'm in is a slab home with copper tubes below the slab that heat it through a boiler. I had to cut through the slab to move some drains around. In doing so I've severed several copper lines. I knew that this could occur but I figured and was told that I could simply solder up the lines afterwards.
Well the problem is that there are three lines that were actually imbedded in the concrete. So now I've got these nice little copper rings in the face of the concrete where the saw went through. The copper is soft and none of the pipes are round they are all oval shaped. Also the concrete is very hard. Very very hard.
How can I get this thing back together? Help please!
Tom
P.S. The only good news is that prior to this project I installed a forced air system so that is my back up. The problem is that the floor will always be cold if I can't get this fixed and I believe the house will always feel cold because of this.
Tom
