Septic trouble
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gundogblue, Oct 24, 2008.
  1. gundogblue
    gundogblue New Member
    Feb 15, 2008
    I posted about a month ago about a wet spot in my yard, we come to the conclution that it MIGHT be consiquential water because the problem did'nt start until we had about 6 inches of rain . The wet spot is still there, but so far nothing has backed up in my home, but I decided to get the septic tank pumped out. The septic tank is located under my deck, so I had to dis-assemble my deck, and when I got the deck boards off I found that there is a good-sized hole in the ground, and I can see septic water in it!!? I called a septic tank repairman and told him what I found and that I intend to have the septic tank pumped out, but he told me not to pump it out until he can come over and assese the situation. He will be here tomorrow morning. Do any of you guys have any idea what might be going on with my septic tank?
    Thanks for any info,
    Paul :confused:
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    As goofy as this would be, maybe somebody simply left your tank's access open for some reason a long time ago and you are seeing down into the tank. Having the tank pumped is a good idea from an overall maintenance standpoint, but yes, first be sure someone who knows septic systems does an overall assessment. Sometimes the pumper can do that, but not all pumpers are experienced installers and technicians.
    Still having that wet spot out in your yard would seem to indicate a drainage problem of some kind.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm sure no expert on septic systems. Had one on the farm when I was a kid, but that's as close as I can come. That said, I gotta agree with Leejosepho. Get a professional assessment done by a qualified technician before doing anything more. The guy that does the actual pumping is most likely just a hired hand that can do the pumping job but isn't an expert technician able to diagnose the problems in the system. Another day or two won't make any difference now.
  5. gundogblue
    Feb 15, 2008
    I have a septic repairman comming out tomorrow, Im in a hurry to get this problem resolved. But since I have never had to have any septic work done would it be better to get a couple estaments especially if the price is extreemly high, although I suspect that every aspect of septic system repair is going to be extreemly expensive.
    Paul :confused:
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    See what the man says..
    It is what it is...
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    As I said previously, another day or two isn't going to matter. This is not something that has suddenly broken and must be repaired ASAP. Of course you don't want it to go on and on, but take a deep breath and get some estimates.
  8. Cass
    Cass Plumber
    Nov 12, 2005
    I will bet some "very smart" home owner when building the deck said to them self...
    "wow how am I goig to get the lid off the tank after I build the deck when it needs to be pumped when suddenly [​IMG] and they said I
    know ...I'll just take the lid off now and leave it that way so it will be easy to pump later...I'll only have to take off a couple of boards to pump it...the stink won't be to bad and no one will get sick...
  9. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Pump it out and keep me posted...
Similar Threads: Septic trouble
Plumbing Forum, Professional & DIY Advice Help!! Septic trouble! Mar 14, 2012
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Roots growing into septic tank Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Help with septic drainage field possible leakage on hill Sep 14, 2016
