1. Woodenshoe
    Woodenshoe New Member
    Jun 16, 2008
    I have been all over the forum asking questions, I hope y'all are not tired of me yet:rolleyes:
    I have a septic tank that will be emtied tomorrow just as a preventive, it has been probably 5 years since last done and it was because it was backing up. The house was build by my wife's pop, rest in peace back in the early 80's.
    When they need to pump the septic tank a heavy lid needs to be lifted, approximately 27"x57". This is just part of the lids. I probed and the total length of the tank is alittle over 10 ft. I will measure the depth when he comes over tomorrow so I can approximately calculate the volume.
    I remember the only pipe I saw going into the tank from the house was a small one, I think a 2-4".
    I wonder if there are more pipes connected from the house that go into this tank, I assume a bigger one from the toilets???
    Included is a picture from the first part of the lid where the small pipe is located.
    Is it possible to get another lid for easier acces with maybe a hole in the top??
    Just new into septic tanks so any advice will be appreciated. The only info about the drainage field is that there are 3 pipes drained into the field??
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    It would have been nice if they had put a couple of handles on that lid.
    Septic tanks for the most part don't plug up for years. As long as the bacteria is alive and well, they do a great job of taking care of solids. If the tank is backing up, it may be a drain field problem.
    I think the tank cleaner guy is going to like that large hole so he can get the hose in and clean the entire tank. A small hole might restrict his ability to get all the goodies out.
  4. mcrandi
    mcrandi New Member
    May 2, 2009
    it is very vital to clean it once every 3-4 years time and also to use proper septic tank cleaners
  5. Leaky Boot
    Leaky Boot New Member
    Jun 25, 2008
    Ron, if your handy you could make up a new lid with a round access hole and buy a poly riser and lid from someone like Polylok , or other suppliers. They are about 24inch dia and you can size them to be just flush with surface so you have access and can also mow over them.
    Most tanks have just one 4 inch inlet and one 4 inch outlet ---that I have seen. LB
Similar Threads: septic tank
Pumps and Tanks Well Forum & Blog. Water is life. Septic tank. $200 down the Hole? Apr 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Septic tank design Apr 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Risers on septic tank - filter inspection lid Aug 10, 2014
Pumps and Tanks Well Forum & Blog. Water is life. New Septic Tank required....grr Apr 28, 2014
Pumps and Tanks Well Forum & Blog. Water is life. How fast should water be flowing into a septic tank? Sep 18, 2013
