Septic Tank Material
Discussion in 'Toilet Forum discussions' started by librazone, May 27, 2006.
  1. librazone
    librazone New Member
    May 20, 2006
    Is there any difference between a polyethylene and a polypropylene septic tank as far as durability and resistance to various chemicals.
  2. vaplumber
    vaplumber Guest
    I would go with a concrete tank. The plastic based tanks all seem durable, but locally when pumping out any plastic or fiberglass tank they tell us that we have to refill the tank with water to protect against possible collapse. With a concrete tank, you pump it out, cover it up and forget it, and the drainfield lines get a much needed rest for a few days so the ground can semi dry out as the empty tank refills. With a plastic or fiberglass tank you have the added cost of hauling in anywhere from 750 to 1500 gallons of water when you empty the tank, and since you refill the tank with water the absorption system never gets a rest. Concrete costs a little more but if you buy one that is reinforced (rebar or steel mesh) it should outlive you and probably your children as well. Speak with Mike50 about this as he is going through a replacement now.
  4. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    If you are going to be there for a long time-get concrete if it's in your budget as it will last as long as your home does.
    My concrete tank goes in next week. If I had planned on only being here for 5-10 more years then I would Not have spent the extra money and opted for a synthetic which is much cheaper.
  5. hj
    Fiberglass tanks, which is the option to concrete here, can collapse from the weight of the ground above them, and it can happen whether they are filled with water or not.
Similar Threads: Septic Tank
Toilet Forum discussions Septic Tank pumped out - do I need to add anything? May 22, 2016
Toilet Forum discussions Toilet to Septic tank issues Jul 4, 2013
Toilet Forum discussions Septic Tank Periodic Treatment Jun 1, 2013
Toilet Forum discussions Septic Tank Full Again Dec 27, 2012
Toilet Forum discussions Septic Tank Nov 20, 2012
