Septic Stains in Shower Pan
Discussion in 'Shower & Bathtub Forum & Blog' started by janmor58, Jan 26, 2009.
  1. janmor58
    janmor58 New Member
    Jan 26, 2009
    A few months ago our septic backed up. Every since then the shower pan has a stain on it that I can't get out. I've tried bleaching and scouring powders, oxyclean. Nothing has worked. I think that the pan is plastic, but it may be fiberglass. I always tape the drain up to prevent the cleaner from going down the drain and causing another problem. I sure appreciate any suggestions.
  2. jadnashua
    Some people have had good luck with a Magic Eraser. If the fiberglass has microfractures in it, you may never get it clean. that's a common problem with older fiberglass stuff that was not embedded in something like concrete, plaster, etc.
  4. janmor58
    janmor58 New Member
    Jan 26, 2009
    WOW....thanks for the suggestion. It took about three of the "erasers" to do the job, but it took it straight off. I did not have to use any other cleansers with it either, which is great so I did not get the septic system balance messed up. THANK YOU, THANK YOU, THANK YOU!!!!
Similar Threads: Septic Stains
Shower & Bathtub Forum & Blog 8 shower heads on septic looking for grey water diverter Jan 15, 2014
Shower & Bathtub Forum & Blog Bathtub drain need "p" trap? Septic smell May 4, 2013
Shower & Bathtub Forum & Blog Need Opinions on Grout Water Stains Outside of Curbless Shower Jan 24, 2015
Shower & Bathtub Forum & Blog removing brown stains on grout without acidic product (don't want to etch it) Nov 5, 2013
Shower & Bathtub Forum & Blog Remove iron stains from refinished tub? Sep 21, 2009
