Septic smells outside the house
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by west, Nov 17, 2008.
  1. west
    west New Member
    Nov 17, 2008
    We just had an addition added to the main house and at the same time we enlarged the septic tank from 1k to 1.5k gallons. Since then we smell the septic system outside, around the house, at different times. The smell is coming from the vent pipes the come out of the roof in the new addition.
    We never had this problem before. I'll assume for the moment that all the new plumbing was done correctly because it was inspected (but you never know). The septic tank drains down to a distribution box about 200 feet away from the house and about 50 feet lower in elevation. The distribution box inside looks good and the field seems to be working, nothing is perking up from the ground nor backing up; everything below the septic tank worked before the addition was added. And we just had the tank pumped out and it did not make a difference.
    Where do I start to look to solve the problem of smelling vent gas outside the house at times?
    Is there a logical path or list of steps I can check to troubleshoot this problem?
    Any pro answers or suggestions to follow a sequence of logical inspections would be greatly appreciated.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  4. west
    west New Member
    Nov 17, 2008
    Putting a "filter" on the vent pipe might be one solution, however we never had this problem before with this house or previous houses, with sewer lines or septic tanks.
    What causes the problem?
Similar Threads: Septic smells
Plumbing Forum, Professional & DIY Advice Septic with drain: outside smells when cold, gurlging in toilet and sink Nov 12, 2011
Plumbing Forum, Professional & DIY Advice Aerobic septic tank smells inside house Apr 18, 2011
Plumbing Forum, Professional & DIY Advice Yuck! shower smells like a septic tank May 20, 2007
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
