Septic line clogged
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sparkync, Apr 2, 2013.
  1. sparkync
    sparkync New Member
    Aug 13, 2009
    I have one commode in my house where the lines are slow to drain. I have a company coming out to pump out my septic tank, but I think I may have another problem. The commode that is slow is "up line" from where it goes in the ground. I have a commode almost directly above where it goes in the ground and is draining alright now. It does make a "gurgling noise" when flush though. I think even after I have the septic tank pumped, I will need something I can pour into the one commode lines that will help clean it out. Any suggestions that will work? I started to get "Rid-X", but have seen on some forums that it is a waste of money. Thanks for any suggestions. The one line that will not drain right is about 25 to 30 ft. from where it goes into the ground. Thanks again..
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    From your description, we don't know if the problem is in the toilet or in the line.
    When everything is working properly, you should be able to dump a 5-gallon bucket of water into the bowl and it should go right down.
Similar Threads: Septic line
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Replacing line from house to septic tank Mar 8, 2016
Plumbing Forum, Professional & DIY Advice Line between house and septic tank sinking Dec 13, 2015
Plumbing Forum, Professional & DIY Advice Advice on rocks for septic line, and corrugated to PVC adapter. Apr 27, 2015
