Septic Design Issue
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by telleee, Jun 1, 2005.
  1. telleee
    telleee New Member
    Jun 1, 2005
    I bought a house a year ago and the septic drain line to the leach field froze and broke this winter. I have repaired the line however, I realized that the leach field is ultimately lower than the septic tank although the drain line has a change in grade along the way and the pipe is full between the leach field and somewhere near the change in grade. My leach field is approximately 600-700ft from the tank and I live in Colorado at 9600ft so the winter months are extremely cold. Is there a way to correct this problem without major renovations of the system?
    The drain line is only about 18" deep where it froze so I was planning on bringing some fill to cover the line to about 40" although with the line full I am not sure this is the fix.
    Thanks in advance for any advice.
    Telleee
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I know next to nothing about septic systems, but I'm almost certain that the drain line to and from the septic tank should be sloped like a drain to a sewer main at 1/4" per foot. It should not have standing water to freeze. If the change in grade creats a low spot, that would have to be removed, and just piling more soil on it will not fix the problem.
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Consult your local Health Department for their advice on modifying, repairing or changing your septic system. They also may require a permit to do it.
    They will be the local experts, or can refer you to a contractor or someone else who is for your locale.
    Good Luck!
    Mike
Similar Threads: Septic Design
Plumbing Forum, Professional & DIY Advice Septic inspection design issues Dec 2, 2009
Plumbing Forum, Professional & DIY Advice Septic tank design help Jul 4, 2006
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Roots growing into septic tank Oct 16, 2016
