Molo
Hello All,
We have electric baseboard heat in multiple rooms with multiple thermostats. It hasn't been used in years and we want to get it running. We want to replace the transformers that are mounted on the sub-panel. The sub-panel is dedicated to the heat and has 7 transformers mounted on the outside. The transformers have the low-voltage thermostat wire coming into them and heavier wires going into the panel. I want to be sure we are replacing the transformers with the correct equipment, and would appreciate some direction on how to select the correct transformers.
Thanks in Advance,
Bill
Thanks in Advance,
Bill
