Seized Bathtub Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by fbskiracer, Feb 5, 2009.
  1. fbskiracer
    fbskiracer New Member
    Feb 5, 2009
    We have an old Eljer Bathrub faucet with diverter that I can't remove from the wall and appears to be seized up. It is not the slip on type and has some sort of screw on assembly. When i attempt to rotate the faucet counter clockwise both the hot and cold water handles try to rotate as tension forms on the pipes.
    Any thoughts on how to remove this faucet? The only reason we need to d anything is because the diverter washers are incompetent now and the shower has no pressure.
    The house is for sale so this is a minimal repair fix needed here.
  2. hj
    faucet
    We might be able to help if we knew what you are talking about. We don't know what you are trying to turn, or how you are trying to get into the faucet. A picture might be better than a description.
  4. fbskiracer
    Feb 5, 2009
    I'm literally trying to turn the faucet counter clockwise to unscrew it from the pipe and I think that is what is seized up
  5. hj
    faucet
    The problem is we do not know WHAT you are trying to turn or if it is even the correct thing to turn.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    Picture would help. General comment....before trying to unscrew any stems, they must be partway open. Do not try to unscrew a closed stem.
  7. buffalobobcasale
    buffalobobcasale New Member
    Nov 12, 2008
    If you're trying to spin the entire faucet, that won't satisfy what you are hoping to accomlish.
    If you need to replace a diverter washer, you should be trying to remove the diverter stem only.
    If that is what is seized, try spraying a little lubricant near where the threads meet the valve body. This might loosen the stem for removal.
    If you check at The Answer Line, a website that features faucet repairs, you might find a schematic of the particular valve you are trying to repair.
    Regards
    Buffalo Bob
Similar Threads: Seized Bathtub
Shower & Bathtub Forum & Blog How to tighten bathtub brass insert Mar 22, 2017
Shower & Bathtub Forum & Blog Is volume control really necessary for bathtub/ shower combo? Mar 4, 2017
Shower & Bathtub Forum & Blog Clawfoot bathtub gurgles Feb 20, 2017
Shower & Bathtub Forum & Blog How do I remove these bathtub skirt panels? Feb 16, 2017
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
