Seeking advice before purchasing fancy shower system
Discussion in 'Shower & Bathtub Forum & Blog' started by angus60, Mar 2, 2006.
  1. angus60
    angus60 New Member
    Mar 2, 2006
    Howdy, I'm planning a bathroom makeover and I am considering purchasing one of those fancy shower system with body jets and shower head. I'm curious how these systems actually perform with the 2.5 gallon flow restriction. Do the body jets reduce pressure from the shower head?
    Along the same line, if you purchase a shower with multiple heads is the combined pressure out of all heads 2.5 gallons or is it 2.5 gallons per head?
    Thanks for the help
  2. hj
    volume
    The volume, not pressure, is 2.5 gpm per head until you reach the maximum volume that the valve can deliver. At that point the gpm will drop in all the heads that are being used.
  4. angus60
    angus60 New Member
    Mar 2, 2006
    Thank you for the reply. Since my original post I found the following information at faucets.com
    http://www.faucet.com/decor/static.pl?S=basics/help_custom_shower_systems
    I take this to mean that on a double headed shower each head can provide 2.5 gpm so long as the valve can permit it.
    The article also mentions using a 3/4" valve versus a 1/2" valve. Are these valves usually included with the shower system or must they be purchased seperately? Are these valves dependent on the size water pipes?
    Thank you so much for your assistance.
Similar Threads: Seeking advice
Shower & Bathtub Forum & Blog Seeking advice on used jacuzzi tub for new bathroom Nov 30, 2012
Shower & Bathtub Forum & Blog (another) Seeking bathtub choice advice (thread) Jul 22, 2010
Shower & Bathtub Forum & Blog Delta 1500, Seeking help with shower update. Apr 21, 2017
Shower & Bathtub Forum & Blog Seeking top quality multi-setting hand-held shower nozzle Jun 28, 2011
Shower & Bathtub Forum & Blog Seeking shower Fan for a teeny itsty bitsy bathroom Jun 27, 2009
