Remington351
Hello Everyone,
I've got a question about sediment filter on my well water system.
Current system is as follows:
200ft well
Gould 7gpm pump 3yrs old
Pressure tank with 30-50 switch
4.5x10 sediment filter cartridge pleated 5 micron
1.5cuft Ph neutralizer with Fleck 2510 head
1.5cuft softener fleck 2510
Water testing:
Ph 5.4
Hardness 210 mg/l
TDS 249 mg/l
Nitrate 9.2
The water has what the local testing company called "Colloidal Clay/Silt". It is very fine, some of which are less then 5 microns. I do get about a pinch of sand/gravel in the filter housing every 2-3 months.
I want to improve the pressure flow through the entire system which is currently bleeding about 8 to 15psi as the 5 micron filter becomes loaded. This affects showering performance on the second floor and I'm concerned about low pressure affecting the back-washing of the tanks.
My concern is if I remove increase the pore size above 5 microns, the very fine sediment will flow through the neutralizer into the softener. Could this fine sediment create a condition where it coats the resin beads and either fouls or diminishes the effectiveness of the softener resin? If yes, what can be done to remove such small particulates?
Thanks.
200ft well
Water testing:
Ph 5.4
Hardness 210 mg/l
TDS 249 mg/l
Nitrate 9.2
Thanks.
