Securing PB and bibb
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by luvrbcs, Jun 20, 2008.
  1. luvrbcs
    luvrbcs New Member
    Aug 9, 2006
    Pennsylvania
    I have PB piping. The outside hose bobb is copper and it is connected to the PB with a fitting.
    The hose bibb is not secured to the outside of the house, there is nothing to attach it to the house with, just vinyl siding and a hole in the rim board that is a larger diameter than the bibb. I can rotate the bibb several degrees to either side.
    Any suggestions on securing the piping on the inside the house?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I wouldn't want to stress the poly-b either by having it loose and twisting it in use or, twisting it to mount. It might be best to pick up a piece of stainless steel sheet metal slotting it to go around the hose bib, securing it to the wall then securing the hose bib to it with stainless steel tec screws.
    [​IMG]
  4. luvrbcs
    luvrbcs New Member
    Aug 9, 2006
    Pennsylvania
    Thank for the idea, I was at a loss, never had to think about this stuff.
    I have the space so instead of sliding stuff under the siding, I might substitute the SST with a piece of plywood on the inside to give the screws in the bibb something to bite into.
    Thanks. :)
    t
Similar Threads: Securing bibb
Plumbing Forum, Professional & DIY Advice Securing PEX Nov 6, 2015
Plumbing Forum, Professional & DIY Advice Securing Flange to New Concrete Jan 26, 2015
Plumbing Forum, Professional & DIY Advice securing copper pipe Mar 24, 2013
Plumbing Forum, Professional & DIY Advice Securing a wobbly PVC stack Mar 18, 2013
Plumbing Forum, Professional & DIY Advice Securing Pex and Valves to Joists? Jan 17, 2013
