secondary stack
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jeffrey, Nov 9, 2004.
  1. jeffrey
    jeffrey New Member
    Nov 9, 2004
    I am building an addition on my house. The existing house has
    a powder room which is serviced by a secondary stack. The addition
    plan calls for a bathroom (shower, sink, toilet). The new bathroom
    will be located right beside the existing powder room such that
    the new toilet is approx 7 feet from the existing stack.
    I am not totally sure if the stack I have referred to is a secondary.
    This is because it is located where the drain leaves the house to
    the city sewer and therefore it could just be a small stack.
    Question: Can I use the existing secondary stack for the new bathroom
    drains?
    Any info is appreciated.
  2. hj
    stack
    You can tie the vents from the new bathroom into that stack, in most cases, but it will not vent those new fixtures by itself.
  4. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    There is way too much we don't know to advise you. The layout of the new bathroom and how your existing plumbing is run will determine what you can do. I am guessing that it will not be nearly as straightforward as you want it. You need a plumber to advise you.
    Deb
    The Pipewench
Similar Threads: secondary stack
Plumbing Forum, Professional & DIY Advice T-wye or Sani-t on 3" secondary stack Jan 24, 2011
Plumbing Forum, Professional & DIY Advice secondary vent stack ending in attic Jun 23, 2006
Plumbing Forum, Professional & DIY Advice Condensation pump secondary runoff Aug 1, 2015
Plumbing Forum, Professional & DIY Advice How to fix condensate line draining to vent stack? Thursday at 7:06 PM
Plumbing Forum, Professional & DIY Advice Drain design with stack in middle of 2 sinks + washer Mar 15, 2017
