Sears Power Miser 12- Similar Symptoms as the stickied Whirlpool Flamelock ?
Discussion in 'Water Heater Forum, Tanks' started by chefwong, Jun 4, 2011.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Hi All -
    I have a Sears Power Miser 12, circa. Late 2006 model.
    It just started doing this where the pilot light goes out.
    I light the pilot, then turn up the temp. It looks like it brings the water to temp and then the pilot goes out . So for the past day, I've been doing the same old routine pilot-boil water and then in between errands and stuff, follow the same routine.
    In search of a fix, I came across this thread.
    On the famous thread sticked for the whirlpool, would the fix possibly be applicable as per above ?
    Boiler was replaced on a whim due to leaking tank, and go figure....their xtended warranty is terrible. The earliest appt I could get from them is 2 weeks out.
    Don't laugh but my previous copper boiler was like 30+ years old .
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yep...
    It's the same damn junk...
  4. chefwong
    chefwong Member
    Jun 14, 2006
    Been looking at Bradfords online.
    When looking at specs, is the only big difference the venting systems....
    There seems to be 3-4 variants in the natural gas lines - 50 gal
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Which ones are you looking at?
  6. chefwong
    chefwong Member
    Jun 14, 2006
    Defender Extra Recovery unit.
    Unless you can recommend a 60 gallon with a 60" H footprint max (vent stack is currently a smigen higher )....
Similar Threads: Sears Power
Water Heater Forum, Tanks Gas Water Heater from Sears without parts -Alternated solution Nov 1, 2011
Water Heater Forum, Tanks Bradfor White being installed next week...if in market for WH avoid SEARS!! Dec 30, 2009
Water Heater Forum, Tanks Power Vent Water Heater Venting Jan 13, 2017
Water Heater Forum, Tanks AO Smith GPSH 50 200 No power Nov 18, 2016
Water Heater Forum, Tanks Direct vented vs power vented water heaters Jun 8, 2016
