masisneros
I purchased this water softner 3 years ago this month and it has worked fine up till now. Mechanically, it works fine, the only problem is the water is not as soft as it should be-I suspect the resin needs to be replaced. Water is at 36 grains of hardness-not sure about iron content.
Everything is fine with it-the water is just not as soft as it needs to be.
My question, should I go through the trouble of replacing the resin? Is it hard to do?
Should I just replace it with something else? I read a thread recommending replacing their sears with a Fleck or Autotrol-should I do this? Will they fit easily in the same space and are they actually better than what I have?
Please help!
Mike
Please help!
Mike
