JR Moore
- Messages
- 2
- Reaction score
- 0
- Points
- 1
Anyone know of a "long hub", Over 3" toilet flange?
I'm replacing a toilet flange which has a 3" (3.5" OD) PVC vertical drain pipe in the cement. I hammered out the cement and removed the old toilet flange. However, the old vertical PVC pipe has a very small hairline crack in it at the top 1" or so. I am looking for a closet flange which will fit over the 3" pipe but extend down farther than the standard 4x3 flanges. The standard flange only covers the top 3/4" of the vertical pipe when placed at the finished floor level. I'd like to go down perhaps 2" farther than the standard 4x3. Ideally, if it had 6" long hub, I could cut it down to my needs.
I have found several 3" x 6" long hub replacements that fit INSIDE a 3" pipe, but just due to flow restriction and alignment considerations, would much prefer to go outside the 3" pipe.
Does anyone know the make/model of a "long hub" 3" or 4x3 closet flange? PVC preferred but ABS is acceptable. Looked all over the internet and can't seem to find one. Maybe I'm approaching the problem incorrectly? However, to cut off the pipe and replace it would be a major job.
Thanks much!
Thanks much!
