Sealing Toilet Bottoms
Discussion in 'Toilet Forum discussions' started by motonutz123, Oct 22, 2011.
  1. motonutz123
    motonutz123 New Member
    Jul 20, 2008
    New York
    Hi,
    I just bought an American Standard toilet and the instructions say to put a bead of sealant around the toilet base and then turning it over and installing the toilet. I would think that doing that would prevent someone from seeing any leaks if the wax ring leaked and make it harder to remove the toilet if there was a leak. What would be the reason to but sealant on the bottom of a toilet?
    Thanks for your replies.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Think boys or men with bad aim.
    I read a sign in a Chinese restaurant washroom.
    We aim to please.
    You aim too, please!
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Don't put any sealant on the back side of the bowl then if the wax leaks you will see it before it can causes water damage.
    John
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Use a latex caulk, not silicone which is too difficult to remove. As noted, this is to prevent water from getting under the toilet. Some plumbers caulk all the way around, but most leave the rear open. The caulk also helps keep the toilet from moving.
    [​IMG]
  6. motonutz123
    Jul 20, 2008
    New York
    Thanks John and Gary for your replies. Caulking and leaving the back of the bowl open makes lots of sense and using latex caulk in this application makes sense also.
Similar Threads: Sealing Toilet
Toilet Forum discussions Sealing a Toilet while away for 6 months. Apr 23, 2015
Toilet Forum discussions Toilet running because not sealing properly Sep 2, 2014
Toilet Forum discussions Sealing Toilet to Floor help Jul 3, 2010
Toilet Forum discussions Vinyl floor at toilet flange sealing question (photo attached) Apr 6, 2010
Toilet Forum discussions sealing a flexible metal water supply to toilet Jun 12, 2007
