Sealing Pex Radiant Tubing with a Sealant??
Discussion in 'HVAC Heating & Cooling' started by footsie, Nov 3, 2008.
  1. footsie
    footsie New Member
    Nov 3, 2008
    I've had a chronic small leak (apparent by a pressure loss) in the 7/8" pex tubing that I used for a radiant heating system. The 700+ ft. of tubing is inaccessible from the top under a hardwood floor and 3/4" plywood. The tubing is inaccessible from below as it is installed over 3/4" plywood which is over insulated 2x12s which is above an older concrete slab that was formerly a patio. The pex was purchased from The Radiant Floor Company in Vermont and was pressure tested before covering, though after one nick in the pex was repaired using barbed couplings secured by hose clamps. Radiant has not been helpful in solving this situation. I've tried "Silver King" boiler additive with no success (the manufacturer said it would work with pex). Is anyone aware of a product that would have the ability to seal this leak and hold it within the operating temp (up to 200 deg) and pressure range (12 to 15 or 16 psi) of this system.
  2. Steven62
    Steven62 New Member
    Aug 22, 2007
    Design Assistant, Watts Radiant
    Missouri
    The only way I know of to permanently fix that, is to re-do the repair and use a high quality clamp made for the system....
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    boiler seal will not work with pex. Pex tubing is too slippery for the chemical to bond to. Barb couplings and hose clamps is a hack repair also. Pex needs to be repaired using the proper fittings. Who installed this and why was it not pressure tested before it was covered up?
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Some of these radiant/hydronic install questions always have me wondering why they are not talking to the plumber (hopefully it was a plumber!) who they were working with.
  6. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Betcha it was a DIY install.
Similar Threads: Sealing Radiant
HVAC Heating & Cooling 555 FlexFix UL Listed Tape sealing the joints on my rigid aluminum dryer ducting Mar 24, 2015
HVAC Heating & Cooling sealing of vent pipe at ceiling Dec 30, 2013
HVAC Heating & Cooling Sealing air leaks Oct 7, 2009
HVAC Heating & Cooling Radiant heat and domestic water on same system? Monday at 8:06 AM
HVAC Heating & Cooling Radiant in concrete - Higher temp/more cycles versus Lower temp/constant circulation Jan 11, 2017
