sealing gas pipe threads ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Fabricator, May 2, 2010.
  1. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    hello. sorry for such a newbe question. but i have never messed with gas pipes. my hwh started leaking. so i am about to replace it. it is natural gas. is plumbers putty good for the threads ? if not, what ?
    if there is anything you would like to add to a first time 40gl gas hwh swapper ?!
    thanx
  2. hj
    One word of advice, "Do not depend on the original installation to meet current installation requirements". You cannot always put the new one in just like the old one was, and if you think plumber's putty is a proper thread sealant for ANYTHING, especially gas, then you have NOT done much piping.
  4. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    yeah. i can't count the # of code violations i have had to repair from the builder. i think the code officer was in the pockets of the builder.
    ok, then what should i use ? i forgot to get a pan when i baught the richmond hwh yesterday. so i have to go to HD anyway.
    thanx
  5. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    oh, btw.
    GREAT state you have there ! that stuff WOULD NOT happen here in il.
  6. hj
    I wouldn't say that, but any pipe joint compound will seal the threads.
  7. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Fill the WH with water and purge the air from the system before you fire it up.
  8. jimbo
    jimbo Plumber
    Back to the question>>> plumbers putty is never used on threads of any kind. PIPE DOPE, also called pipe thread paste, is what to use. Great White, Megaloc, Rectorseal Tplus2, are some good ones.
  9. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Don't forget to use a soapy water solution on the gas pipes when you turn the gas back on, we want zero leaks
  10. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    thanx guys.
    WH is in. i put a pan/drain in.
    i flushed the living poop out of it. i would say at least 100 gallons.
    i used Tplus2.
    i soaped up the joints. no leaks.
    and new dielectric fittings and a new shut off valve.
    idk what kind of sealer the builder used. but it sure looked like plumbers puddy.
    i have another question. on the in/out fittings of the WH. there is a blue plastic gasket (for lack of a better term). what is that for ?
    thanx
  11. jimbo
    jimbo Plumber
    If you are talking about the nipples that often come pre-attached to the water heater, the blue is a plastic dielectric lining to prevent corrosion of the outlet fitting.
  12. hj
    quote; the blue is a plastic dielectric lining to prevent corrosion of the outlet fitting.
    That is what it is SUPPOSED to do, but seldom does it.
  13. Fabricator
    Fabricator Member
    Jul 5, 2009
    Illinois
    yes, the pre-attatched nipples. i looked down in these nipples. there looked to be some kind of valveage down there about 2"s. what is that for ?
    thanx guys :)
Similar Threads: sealing pipe
Plumbing Forum, Professional & DIY Advice Sealing pipe through concrete Yesterday at 11:26 AM
Plumbing Forum, Professional & DIY Advice Sealing pipe threads with large gap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Sealing around septic pipe Jul 11, 2013
Plumbing Forum, Professional & DIY Advice advice on sealing/plugging holes in PVC pipe Aug 2, 2010
Plumbing Forum, Professional & DIY Advice Cast Iron pipe - Lead removal and resealing Feb 28, 2010
