Sealing drain tailpipe threads
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Deane, Nov 8, 2004.
  1. Deane
    Deane New Member
    Nov 8, 2004
    I've installed a few bathroom sink drains in my house (with overflow), and there's one thing I still can't figure out: how do you prevent water from seeping down the drain tailpipe's outer threads, underneath the rubber sealing washer that seals it to the sink bottom? I can't believe you're supposed to tighten the nut hard enough to mash the rubber washer fully into the threads. Or do I use teflon grease on the threads?
    Does anyone out there have a good technique for this?
    I checked under a few sinks at work, etc, and they all have the Crust of Ages on the threads at this joint. Surely I can do better.
  2. Terry
    Aug 17, 2004
    I'm not supposed to tell you this, but a very small amount of plumbers putty mashed into the threads before you pull down the rubber washer will keep that water from running down past the inside of the rubber washer.:)
  4. Deane
    Deane New Member
    Nov 8, 2004
    Terry,
    Thanks! Your secret is safe with me. Great website, BTW. I bought two Toto Carlyles on the basis of your recommendation, and love them.
    Deane
  5. jimbo
    jimbo Plumber
    Darn, Terry! I thought I was the only one who knew this! I was going to write a book!
  6. hj
    leak
    In the book, you can also add that pipe joint compound on the threads and the bottom of the washer also work, and it does not seize the threads so it will not come apart some day like putty will.
  7. jimbo
    jimbo Plumber
    Thanks hj. I usually do try to do things which will make it easier for " some guy " down the road, because sometimes I am the "some guy"! I think I will switch to dope on these drains.
  8. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Dope
    I also use dope and have not had problems sealing metal pop-ups to lavatories.
Similar Threads: Sealing drain
Plumbing Forum, Professional & DIY Advice Tub drain sealing advice. May 20, 2014
Plumbing Forum, Professional & DIY Advice How does sealing of basin drains really work? Dec 28, 2010
Plumbing Forum, Professional & DIY Advice sealing off unused WH drain? Jul 28, 2010
Plumbing Forum, Professional & DIY Advice Sealing around drain Feb 20, 2008
Plumbing Forum, Professional & DIY Advice Sealing pipe threads with large gap Feb 6, 2017
