Sealing air leaks
Discussion in 'HVAC Heating & Cooling' started by rschmitty, Oct 7, 2009.
  1. rschmitty
    rschmitty New Member
    Jan 24, 2009
    Indiana
    I noticed some nasty air leaks from around the windows and was just wondering what is recommended for sealing?
    Here's a picture of the biggest gap 5/16 inch
    http://img183.imageshack.us/gal.php?g=window139.jpg
    around most parts of the windows the gap is very small, 1 to 2 16ths
    For the large gap should I be looking at some kind of expanding foam or just use extra caulking down there
    Latex or Silicone?
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    A white paintable latex will look about right even unpainted, and is good for gaps up to about 1/2".
    Silicones aren't usually paintable, and won't look as good on it's own.
  4. jadnashua
    Couldn't tell from the picture...are the gaps between the window and its frame or between the frame and the wall? If between the window and frame, sounds like since it varies, it wasn't squared up properly during installation. If it is in the wall, and the thickness of the wall, I think some low-expansion foam would both seal and anchor it into the opening...then, maybe a bead of caulk if it is visible and not covered with trim.
Similar Threads: Sealing leaks
HVAC Heating & Cooling 555 FlexFix UL Listed Tape sealing the joints on my rigid aluminum dryer ducting Mar 24, 2015
HVAC Heating & Cooling sealing of vent pipe at ceiling Dec 30, 2013
HVAC Heating & Cooling Sealing Pex Radiant Tubing with a Sealant?? Nov 3, 2008
