Sealing 3" Rodding access Threaded Connections
invisible-man
United Kingdom
Hi, just trying to find out what method you use to seal 3" rodding access threaded connections (with square end) within a drain set up, not sure if PTFE tape is ok or not......
Ones I have looked at seam to be a threading compound, I was just concerned that if a compound was the correct method would this be really hard to undo?
Many thanks!
cleanout
Not sure what you mean by "square end" unless you are referring to the top of a screwed plug. If it is a threaded connection, then any sealer suitable for your material is a proper.
invisible-man
United Kingdom
Yes the square end is the top of the screwed plug (where the wrench would go).......so are you saying that I can use ptfe tape or thread compound
