Sealant recommendation?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by MJDuftler, Mar 20, 2008.
  1. MJDuftler
    MJDuftler New Member
    Dec 7, 2006
    I've just replaced the poly line from my pressure tank to the well cap. In doing so, I had to chip/gouge out the black sealant that surround the poly/vent/wire that went through the foundation.
    I spoke to the pump supply house about what to use to replace this sealant and they mentioned Water Plug and Thermoseal, but I haven't had much luck finding either.
    Can anybody recommend a product and hopefully a web-site that sells it?
    I'm not going to use hydraulic cement because it seems to never last even one season, and the sealant that was there lasted over 2 decades and worked perfectly.
    Thanks,
    -Matt Duftler
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    You can get a can of spray-foam, about $6 at HD or most hardware stores. It is essentially a one-shot item because the material in the dispenser stem cures and plugs up, so if you have a lot of places to seal you can do them all at once.
    The foam is easy to remove when you need to service it.
    You could also use roof mastic, filling the space in multiple applications. One gallon will leave a lot left over for fixing your roof.
    If it is not a big hole you can get tubes of caulking compound. I recently used some "driveway crack caulking" which is probably close to the black stuff you chipped out.
  4. MJDuftler
    Dec 7, 2006
    Hi Bob,
    I hadn't considered the Great Stuff route. Makes sense. And I like the idea of being able to remove it easily if I need to.
    Thanks,
    -Matt
Similar Threads: Sealant recommendation
Pumps and Tanks Well Forum & Blog. Water is life. Sealant and techniques May 26, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Thread sealant Apr 8, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Jet Pump Recommendations? Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well filtration - thoughts and recommendations? Dec 22, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Recommendations for Iron Filter for Landscaping Feb 24, 2016
