Sealant for Flange to Lead Pipe.
Discussion in 'Toilet Forum discussions' started by RaynLois, Apr 14, 2006.
  1. RaynLois
    RaynLois New Member
    Apr 6, 2006
    I need to install a new flange on a lead pipe. The pipe has an immediate elbow under the floor so I cannot use the flange with a neophren gasket designed for this purpose, since its extra length would partially block the pipe. It appears my only choice is to use a standard, shorter plastic flange with some kind of sealant between the flange and pipe rim. Any suggestions about the best type of sealant for this? Silicon? Plumbers putty?
    Or is there a better solution?
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    flange
    The only real way to do what you want to do is get a brass flange and solder it to the lead pipe and screw the brass flange to the floor...
    Just because some manufacturer makes claims doesn't mean that it any good. The easy way isn't always the best way.......
  4. hj
    flange
    Plastic flanges are for plastic pipe. For a lead bend you need a brass flange soldered to the lead.
Similar Threads: Sealant Flange
Toilet Forum discussions Push in toilet flange Mar 14, 2017
Toilet Forum discussions Toilet Flange not Flat/Level Feb 21, 2017
Toilet Forum discussions Urine Smell and Rusted Flange Washer Feb 20, 2017
Toilet Forum discussions Sealing offset flange Feb 12, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
