seal or not around the bottom of the toilet?
Discussion in 'Toilet Forum discussions' started by babifav, Jun 17, 2010.
  1. babifav
    babifav New Member
    Jun 14, 2010
    El Cajon, CA
    I recently replace my toilet and I was wonder if I should seal around the bottom? My contractor told me that I don't have to seal because he already install the wax ring, but I would like to have a second option of it. Because, the toilet is rocking a little bit when you sit on it and I saw on internet some ppl saying no, others saying grout the bottom or caulk or silicon...
    Guys, I'd like to thank you all for your time and thanks Terry for this forum... I can sleep better at night :eek:
  2. Terry
    Aug 17, 2004
    Barb,
    Tell the handyman, that a properly installed toilet bowl should not rock.
    It needs to be reset with new wax, and this time he should shim the bowl before he tightens down the nuts.
    I use plastic door shims. They are the best!
    And then he should use polySeamSeal or something similar around the bowl.
    In Seattle, we leave the back open. We don't have ants here, it's not Arizona.
    We leave the back open in case the wax seal leaks. We have wood floors here.
    In Arizona they caulk it 360.
  4. babifav
    babifav New Member
    Jun 14, 2010
    El Cajon, CA
    Hi Terry,
    Thank you for your attention. I will talk again with my contractor, yes... it's rocking a little bit I'm not sure if it's normal, because the rest of the house has a grout around the bottom. I'm south California, you should move here... It's very difficult to find someone who we can really trust, I've have a lot of problem since I remodel the bathroom... bad lucky perhaps.
  5. Terry
    Aug 17, 2004
    The caulk is to prevent water from going under the bowl, and to secure the bowl to the floor.
    Trust me, you don't want water getting under the bowl.
    It also quiets the bowl to floor contact.
Similar Threads: seal around
Toilet Forum discussions Kohler Wellworth Cannister - Water won't fill tank (seal is new) Monday at 5:17 AM
Toilet Forum discussions Sealing offset flange Feb 12, 2017
Toilet Forum discussions Sani Seal with Offset Flange 1/4" Above Tile Floor Jan 5, 2017
Toilet Forum discussions LOCTITE PolySeamSeal Formula Tub & Tile Caulking Oct 13, 2016
Toilet Forum discussions My tank to bowl seal is leaking Aug 2, 2016
