Seal on Toto drain adaptor for units with drain at back
Discussion in 'Toilet Forum discussions' started by alternety, Jan 31, 2012.
  1. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    A question about the rubber seal on the adapter. The end that the toilet horn enters. Is that rubber seal glued or otherwise attached to the adapter, or can it be replaced?
  2. Terry
    Aug 17, 2004
    If you are talking about a Unifit adapter, it's a rubber seal that the horn drops down into.
    You can put liquid soap on it for lubrication, but normally I just set the bowl down on it.
    [​IMG]
    This is only for the skirted bowls.
    The Drake doesn't use this adapter.
  4. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    It just slips in. If Toto will sell you the seal it can be replaced.
  5. alternety
    Apr 2, 2006
    Washington
    I need to know if I can replace the seal. I need to decide now what to do.
    The plumber that installed it used grease that appears to have compromised the rubber.
  6. Hackney plumbing
    Jan 6, 2010
    Alabama
    Go to Toto's website and see if its offered as a replacement part. I doubt it. You could call Toto and they might can send you just the gasket. I dunno but I can tell you they are not glued in or anything,they just pop in and out.
    I have a 12" and a 10" in my garage and I checked both of them.
  7. alternety
    Apr 2, 2006
    Washington
    By pop out, you mean you can just pull them out - right? That is what I needed to know.
    I have been trying to get one out and it was not coming out with the force I applied. I was afraid of ruining another unifit.
    I tried Toto's store earlier. Search finds no Unifit and I am not sure what the toilet model is.
    I currently have two toilets out of service so I am trying real hard to get one back up.
  8. Hackney plumbing
    Jan 6, 2010
    Alabama
    The grease your plumber used may have caused the rubber to swell. I suppose the swelling could make the rubber harder to remove
    Yes pull it out.
  9. alternety
    Apr 2, 2006
    Washington
    I am still not certain we are talking about the same thing. I am not trying to remove the adapter from anything. I am trying to take the rubber seal out of the adapter.
    I have been sitting watching Avatar and continuing to try to remove the seal. I just do not seem to have sufficient strength to pull it out. I have a new unifit assembly for another toilet. I am trying to reinstall the used (greased) unifit adapter back under the toilet to which it was previously attached. I want to replace the existing seal for the used unifit with one from the new unifit.
  10. Hackney plumbing
    Jan 6, 2010
    Alabama
    I never said anything about an adapter but I'm talking about the black rubber seal shown in the picture that Terry post up the page. That black rubber seal pulls out.
    Goodluck!
  11. alternety
    Apr 2, 2006
    Washington
    Thanks. I will have to figure out how to get it out. I am just not strong enough anymore. That is depressing.
  12. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I doubt that the grease the plumber put on it damaged it, and I highly doubt that it is glued in. It is likely just a tight fit and should come out with a bit of prying. The Unifit adapter is used on several Toto models, and the adapter's gasket is the exactly the same for all of them. I do have to wonder why, if a plumber installed the toilet, did you remove it, and why do you think you have a gasket problem?
Similar Threads: Seal Toto
Toilet Forum discussions Toto was grouted to my tile-cover grout with Loctite Polyseamseal or silicone? 27 minutes ago
Toilet Forum discussions FLUIDMASTER 7530 WAXLESS SEAL AND NEW TOTO TOILETS Jan 22, 2016
Toilet Forum discussions Toto CST454CEFG Drake II not Compatible with Danco Perfect Seal Apr 21, 2015
Toilet Forum discussions Can't locate TOTO Original Flappers or at least the rubber seal gasket. Feb 10, 2015
Toilet Forum discussions Waxless Seal for Toto Neorest 550? - Or stick with Wax? Apr 20, 2013
