screw hole in pvc vent pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by permapak, Jun 9, 2007.
  1. permapak
    permapak New Member
    Jun 9, 2007
    I accidentally ran a #8 screw through the 1 1/2" PVC vent pipe. It's inside the stud at the cutaway. I have limited access to one side and can see the hole with a flashlight. I don't want to remove the drywall to replace the pipe. Can I plug it with silicone or something since it's a vent pipe? Thanks for the help.
  2. jadnashua
    A few of the non-approved fixes that have been kicked around. Put some silicon on another screw and maybe a rubber washer and just screw it in and leave it. Or, get a screwdrive blade hot with a torch and use it to melt and move some of the pvc to fill in the hole. Or, try some epoxy. Or, cut it out and replace.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Try this: I've seen a version of it at Wal-Mart.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It's a vent so there will never be water or pressure in it. Just run a #8 screw in the hole and leave it alone. If it was a drain pipe, then you'd have to seal it.
Similar Threads: screw hole
Plumbing Forum, Professional & DIY Advice Tub spout setscrew poked hole in copper stub Aug 6, 2015
Plumbing Forum, Professional & DIY Advice screw hole in copper pipe Jul 4, 2010
Plumbing Forum, Professional & DIY Advice Repairing Screw Hole in ABS Jan 20, 2008
Plumbing Forum, Professional & DIY Advice Shower fixture screws onto nipple -- but no nipple size works Apr 15, 2016
Plumbing Forum, Professional & DIY Advice Removing Moen shower handle without set screw Feb 20, 2016
