SCH80 pvc cement and primer question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mckeand13, Sep 3, 2010.
  1. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    I will be installing a new fiberglass pressure tank. The in/out connections are 1 1/4†socket weld pvc. I’m planning on gluing some sch80 1 ¼†to ¾†NPT bushings in so I can make my connections with copper.
    Does sch80 gray pvc require any different primer & cement versus sch40 white? I’ve only done DWV before. I have the Oatey Handi pack which contains their PVC Regular Clear Cement and Purple Primer – NSF listed.
    Want to make sure I get this right.
    Thanks.
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Yes the product states up to 2" pipe for sch 80 just make sure to leave to dry for 12hrs for a proper cure before charging the system.
  4. hj
    IT should work, but the can will also have the specifications for the materials and schedules it works on.
Similar Threads: SCH80 cement
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Moen Chateau knob replacement ? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice P Trap replacement Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Replacement Handle for American Standard Tub/Shower Jan 17, 2017
