Sanitary Tee on side?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mastas, Apr 20, 2007.
  1. mastas
    mastas New Member
    Apr 20, 2007
    [​IMG]
    A wye and 45, sometimes called a combination fitting or combo.
    I've googled to the end and couldn't find a definitive answer, so I'm hoping to get it here.
    [​IMG]
    Santee
    Is it possible to use a sanitary tee in a waste line on its side? I'm doing this to change directions/tap into an existing waste line.
    and from the differing answers I found, none of them gave a clue as to why this can't be done, other than to say it can't be done.
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    [​IMG]
    You need a wye, or tee-wye. A horizontal to horizontal change of direction needs to be sweeping.
  4. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    the turn radius on a san tee is too tight, it will eventually have a problem with clogging.
  5. mastas
    mastas New Member
    Apr 20, 2007
    thanks for the quick replys.
    Sometimes, google isn't the best place for information.
  6. dmpogo
    dmpogo New Member
    Apr 10, 2007
    What about vertical to horizontal ? (Although I could feel advantage of
    45+wye in this case as well)
  7. Terry
    Aug 17, 2004
    [​IMG]
    vertical to horizontal, wye
    [​IMG]
    horizontal to horizontal, wye
    [​IMG]
    horizontal to vertical, santee or wye unless the vertical is used as a vent, and then a santee.
  8. mrmedic
    mrmedic Junior Member
    Mar 26, 2007
    Contractor
    Delaware
    [​IMG]
    Are combo's OK? The type that is like a "T" but has a sweep 90 sort of with it?
    This is for a horizontal to horizontal.
    Ron
  9. kordts
    Oct 15, 2005
    exurban Chicago
    [​IMG]
    Yes, a store bought combo is also known as tee-wye. I hadn't seen them until recently, we made them up and always called them combos.
Similar Threads: Sanitary side
Plumbing Forum, Professional & DIY Advice Sanitary T w/ L & R Side Inlet May 19, 2007
Plumbing Forum, Professional & DIY Advice Sanitary TEE with Side Inlet Against Code? May 26, 2006
Plumbing Forum, Professional & DIY Advice Broken sanitary tee in block Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Laundry tub/washer sanitary tee question Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Venting question: sanitary tee vs wye + 45 Jan 3, 2017
