Sanitary T w/ L & R Side Inlet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by OscarG, May 19, 2007.
  1. OscarG
    OscarG New Member
    May 11, 2007
    I found this fitting in a catalog and it seems like it could solve the problem of feeding a W.C., shower drain and lavatory drain into a stack (on a second floor bath) with only a slight drop to the cieling below. I did not want to notch or dirll the joists for pipe so keeping all of the entry points into the stack in the same horizontal plane is most desirable. Above this fitting the stack will be dry (only vent to roof).
    Is this the correct use for this fitting? It just seems a little odd having drain flows directly opposing each other as they enter the stack.
    [​IMG]
  2. hj
    fitting
    It is the correct fitting, but many inspectors will reject it. It is no different than the fitting used to connect two sinks to the same riser, as long as the riser is properly oversized to prevent crossover flow.
  4. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    I just had to replace one of these the other day. It was ABS, which no one stocks around here. The left side 1-1/2" hub had cracked. It was in a 3 story apt. building which settled a little bit. The stress cracked the hub. I used a PVC fitting and tangents and tied into the ABS with shielded couplings. I think the rubber will allow for any additional settling or stress.
Similar Threads: Sanitary Side
Plumbing Forum, Professional & DIY Advice Sanitary Tee on side? Apr 20, 2007
Plumbing Forum, Professional & DIY Advice Sanitary TEE with Side Inlet Against Code? May 26, 2006
Plumbing Forum, Professional & DIY Advice Broken sanitary tee in block Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Laundry tub/washer sanitary tee question Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Venting question: sanitary tee vs wye + 45 Jan 3, 2017
