Hi,
I'm running the 1" dia pvc discharge pipe from my Saniflo "SaniBest" macerating pump in my basement to my house main drain (also in the basement, but 6ft high off the floor). The installation instructions say:
"If you require a vertical lift, it should precede any horizontal run and should commence as near as possible to the discharge elbow (no more than 18 inches away). Once you have started the horizontal run, you cannot change directions in an upward vertical manner."
That's a strange statement because head loss is head loss, no matter whether vertical or horizontal. In my case (overall 6ft vertical lift, overall 10ft horizontal) , I can't run vertically up first because I have to avoid a basement window.
Has anyone had any similar installation experience, and any subsequent issues?
Thanks
Theodore
Thanks
Theodore
