Saniflo Greywater Pumps?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Nate R, Jul 16, 2010.
  1. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    Working on the design of our kitchen remodel. Currently, the kitchen sink is on an inside wall, 2 feet from the stack. We're looking at moving the sink and adding a dishwasher, but putting them on an outside wall, 12 feet away. Our house was built over a dirt "crawlspace" but the dirt is only about 12" below the joists. I'd rather not run the DWV lines under the house, worry about freezing there, and deal with cutting into the stack at grade level, etc.
    Is there any big downside to using a Saniflo Greywater pump system for the kitchen sink and dishwasher only? (Assuming it's properly vented) I'm thinking I could use this, and run the drain line through the ceiling instead over to the stack.
    And how do I choose between the Saniswift model and the Sanivite?
  2. jadnashua
    Gravity always trumps pumps when possible, so I'd not consider using a pump when gravity would work. Other than the trap (which on a kitchen sink would be inside the house), a drain line does not hold water. Running water down the drain is not likely to freeze and plug up the line unless you have a slow leak that continually drips water down the drain line. So, I'd bite the bullet and run new drain lines to the new locations.
  4. Katzz
    Katzz New Member
    Nov 29, 2010
    Canada
    If you're going to the expense of remodelling your kitchen, avoid the grey water pumps. The saniswift and sanivite are fine for hand sinks, showers and short-term temporary usage but as soon as you start draining water that can/will contain grease, food particles or is 1-degree hotter than the maximum threshold, you will have issues. Most of this would not be covered under the extremely limited 2 year warranty - the company will make sure to tell you this repeatedly. Save yourself the grief and spend the extra money on installing proper drain and vent lines.
  5. hj
    Using a pump to discharge water from a kitchen sink and dishwasher is almost guaranteed to create "eternal" problems. Call a plumber and let him deal with providing a proper drain.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'll chime in just to say I agree fully with all the other posters so far.
    Looks like really good advice to me.
    Don't pump!
Similar Threads: Saniflo Greywater
Plumbing Forum, Professional & DIY Advice Saniflo venting. No place to tie in. Aug 16, 2016
Plumbing Forum, Professional & DIY Advice Saniflo toilet pump: routing discharge pipe Aug 15, 2016
Plumbing Forum, Professional & DIY Advice Saniflo pump and toilet issue Aug 22, 2015
Plumbing Forum, Professional & DIY Advice Basement Bathroom - Sewage Ejector or Saniflo? Jul 8, 2015
Plumbing Forum, Professional & DIY Advice Saniflo Toilet install question Jan 12, 2014
