Rollin
- Messages
- 1
- Reaction score
- 0
- Points
- 1
So I'm in a new place that has a sandpoint. Ive tried many things now, other than pulling it out to see if its clogged, or driving it down deeper. Here is what I've done so far as to get it going.. I've added a length of pipe past the discharge for more water prime. added a Tee below the check valve (intake side) in hopes it would draw water easier. This tee has a ball valve so I can add water to the intake side with a hose. I'm in an area where the watertable is high and in abundance. I'm curious if my neighbour has sucked it all towards his pump, about 50ft away! (cant see that being it!).. should i try driving it deeper or pull it, clean it and start again. I've attached a picture. Its a 3/4 HP motor... Thanks for any help!!
